Zum Hauptinhalt wechseln
Lenovo Vibe Z2 Pro Charging Assembly Replacement
Was du brauchst
  1. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: Schritt 1, Bild 1 von 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: Schritt 1, Bild 2 von 2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 3, Bild 1 von 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 3, Bild 2 von 2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 4, Bild 1 von 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 4, Bild 2 von 2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 5, Bild 1 von 1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Battery: Schritt 6, Bild 1 von 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Battery: Schritt 6, Bild 2 von 2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 7, Bild 1 von 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 7, Bild 2 von 2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 9, Bild 1 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 9, Bild 2 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 9, Bild 3 von 3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
  10. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: Schritt 10, Bild 1 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: Schritt 10, Bild 2 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: Schritt 10, Bild 3 von 3
    • Remove the 3.15mm Phillips Head #000 screws from motherboard.
  11. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 11, Bild 1 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 11, Bild 2 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 11, Bild 3 von 3
    • Disconnect the two ribbon cables by gently lifting on the black hinges and pulling away with tweezers
  12. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 12, Bild 1 von 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 12, Bild 2 von 2
    • Gently disconnect the rear-camera connector
  13. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 13, Bild 1 von 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 13, Bild 2 von 2
    • Gently remove the front-facing camera by gently lifting on the connector tab.
    • Remove the other connector by gently lifting with a spudger.
  14. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 14, Bild 1 von 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 14, Bild 2 von 2
    • Pry off the plastic brace along the top edge of the phone
  15. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 15, Bild 1 von 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 15, Bild 2 von 2
    • Remove the antenna connected to the bottom piece of the screen plate
  16. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 16, Bild 1 von 1
    • Gently lift the motherboard off the frame
    • Pull the camera out from behind the motherboard
  17. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 17, Bild 1 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 17, Bild 2 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 17, Bild 3 von 3
    • Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
    • Remove the motherboard completely.
  18. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Charging Assembly & Headphone Jack: Schritt 18, Bild 1 von 1
    • Remove the 3.6 mm Phillips head screws from the charging assembly
  19. Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 19, Bild 1 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 19, Bild 2 von 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: Schritt 19, Bild 3 von 3
    • Gently peel the flat cable away from the screen
    • Gently lift the charging assembly using a spudger
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 18-3, Blackwell Fall 2016 Mitglied von USF Tampa, Team 18-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,006
