Zum Hauptinhalt wechseln
Lenovo Y50-70 Touch Fan Replacement
Was du brauchst
  1. Lenovo Y50-70 Touch Fan Replacement, Back: Schritt 1, Bild 1 von 2 Lenovo Y50-70 Touch Fan Replacement, Back: Schritt 1, Bild 2 von 2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Fan Replacement: Schritt 2, Bild 1 von 2 Lenovo Y50-70 Touch Fan Replacement: Schritt 2, Bild 2 von 2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: Schritt 3, Bild 1 von 2 Lenovo Y50-70 Touch Fan Replacement, Fan: Schritt 3, Bild 2 von 2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50-70 Touch Fan Replacement: Schritt 4, Bild 1 von 3 Lenovo Y50-70 Touch Fan Replacement: Schritt 4, Bild 2 von 3 Lenovo Y50-70 Touch Fan Replacement: Schritt 4, Bild 3 von 3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50-70 Touch Fan Replacement: Schritt 5, Bild 1 von 3 Lenovo Y50-70 Touch Fan Replacement: Schritt 5, Bild 2 von 3 Lenovo Y50-70 Touch Fan Replacement: Schritt 5, Bild 3 von 3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50-70 Touch Fan Replacement: Schritt 6, Bild 1 von 3 Lenovo Y50-70 Touch Fan Replacement: Schritt 6, Bild 2 von 3 Lenovo Y50-70 Touch Fan Replacement: Schritt 6, Bild 3 von 3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50-70 Touch Fan Replacement: Schritt 7, Bild 1 von 2 Lenovo Y50-70 Touch Fan Replacement: Schritt 7, Bild 2 von 2
    • Lift the fan off of the laptop.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Vivian
351 Reputation
1 Anleitung geschrieben
Cal Poly, Team 18-1, Maness Winter 2015 Mitglied von Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 34
Insgesamt: 9,434
