Zum Hauptinhalt wechseln
Lenovo Y520-15IKBN Display Replacement
Was du brauchst
  1. Lenovo Y520-15IKBN Display Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  2. Lenovo Y520-15IKBN Display Replacement: Schritt 2, Bild 1 von 2 Lenovo Y520-15IKBN Display Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  3. Lenovo Y520-15IKBN Display Replacement: Schritt 3, Bild 1 von 1
    • Lift the battery up and out of the chassis.
  4. Lenovo Y520-15IKBN Display Replacement, Display: Schritt 4, Bild 1 von 1
    • Use an opening tool to pry off the display bezel.
  5. Lenovo Y520-15IKBN Display Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 4 mm screws with a Phillips #1 screwdriver.
  6. Lenovo Y520-15IKBN Display Replacement: Schritt 6, Bild 1 von 1
    • Flip up the gate on the display ribbon cable, and pull it directly out of its port.
    • Remove the display from the computer.
Abschluss
Comm 260 Team 15 Mitglied von Comm 260 Team 15
Community
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 42
Insgesamt: 1,233
