Einleitung
This guide will walk you through with replacing the fan of your device. You're going to need to sit down and unscrew a lot of screws to access the fan of your device.
  1. Flip the device so the back is facing you.
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Use the blue Opening Tool to pry-open the back cover.
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
    • Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
  5. Using a pair of blunt tweezers, disconnect the fan from the motherboard.
    • Using a pair of blunt tweezers, disconnect the fan from the motherboard.
    • Remove the fan from the device.
Abschluss
Trevor James
85 Reputation
1 Anleitung geschrieben
What kind of fan is that?
I need to know what to order for replacement.
vlastimil.beno - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 87
