Zum Hauptinhalt wechseln
Lenovo Y70-70 Touch Fan Replacement
Was du brauchst
  1. Lenovo Y70-70 Touch Fan Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Y70-70 Touch Fan Replacement: Schritt 2, Bild 1 von 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Y70-70 Touch Fan Replacement, Fan: Schritt 3, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
  4. Lenovo Y70-70 Touch Fan Replacement: Schritt 4, Bild 1 von 1
    • Using a pair of blunt tweezers, disconnect the fan from the motherboard.
    • Remove the fan from the device.
Abschluss
Trevor James
85 Reputation
1 Anleitung geschrieben
Ein Kommentar
What kind of fan is that?
I need to know what to order for replacement.
vlastimil.beno - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 365
