Zum Hauptinhalt wechseln
Lenovo YOGA 730-15IKB Speaker Replacement
Was du brauchst
  1. Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Speaker Replacement: Schritt 2, Bild 1 von 2 Lenovo YOGA 730-15IKB Speaker Replacement: Schritt 2, Bild 2 von 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Speaker Replacement: Schritt 3, Bild 1 von 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: Schritt 4, Bild 1 von 3 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: Schritt 4, Bild 2 von 3 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: Schritt 4, Bild 3 von 3
    • Disconnect the speaker cable by pulling the wire towards the front of the laptop.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Speaker Replacement: Schritt 5, Bild 1 von 2 Lenovo YOGA 730-15IKB Speaker Replacement: Schritt 5, Bild 2 von 2
    • When the laptop is upside down, the left speaker is located on the right side of the computer.
    • Pull up on the left speaker to remove it from the chassis.
    • Do not fully remove the left speaker at this point. Notice that the left and right speakers are still connected by a wire.
  6. Lenovo YOGA 730-15IKB Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the red and black wire near the front of the laptop from underneath the hooks that hold it in place.
  7. Lenovo YOGA 730-15IKB Speaker Replacement: Schritt 7, Bild 1 von 2 Lenovo YOGA 730-15IKB Speaker Replacement: Schritt 7, Bild 2 von 2
Abschluss
Ellis Ruckman
2.707 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S1-G6, White Winter 2020 Mitglied von Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Mitglieder
27 Anleitungen geschrieben
1 Kommentar zur Anleitung
when the stock can arrive ?
prashantdushara - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 31
Insgesamt: 1,295
