Zum Hauptinhalt wechseln
Lenovo YOGA 730-15IKB Touchpad Replacement
Was du brauchst
  1. Lenovo YOGA 730-15IKB Touchpad Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo YOGA 730-15IKB Touchpad Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Touchpad Replacement: Schritt 2, Bild 1 von 2 Lenovo YOGA 730-15IKB Touchpad Replacement: Schritt 2, Bild 2 von 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
    • Pull parallel to the battery, not straight up.
    • Unplug the cable gently as the eight wires on the connector are very small and delicate.
  5. Lenovo YOGA 730-15IKB Touchpad Replacement: Schritt 5, Bild 1 von 2 Lenovo YOGA 730-15IKB Touchpad Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 4mm Phillips #1 screws securing the battery.
  6. Lenovo YOGA 730-15IKB Touchpad Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery up and out of the chassis.
    • Handle the battery carefully. Touching the terminal may cause electric shock. Puncturing the battery may cause it to catch fire.
  7. Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: Schritt 7, Bild 1 von 3 Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: Schritt 7, Bild 2 von 3 Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: Schritt 7, Bild 3 von 3
    • The touchpad is connected by a ribbon cable to the front edge of the motherboard.
    • Pull up on the black tab on the touchpad cable connector.
    • The ribbon cable should easily pull out of the connector.
  8. Lenovo YOGA 730-15IKB Touchpad Replacement: Schritt 8, Bild 1 von 1
    • Remove six 2mm Phillips #000 screws.
    • Some of these screws may be hidden under other ribbon cables.
  9. Lenovo YOGA 730-15IKB Touchpad Replacement: Schritt 9, Bild 1 von 2 Lenovo YOGA 730-15IKB Touchpad Replacement: Schritt 9, Bild 2 von 2
    • Pull up on the top edge of the touchpad near the motherboard. Lift the touchpad up and out of the chassis.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S1-G6, White Winter 2020 Mitglied von Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Mitglieder
27 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 31
Insgesamt: 2,074
