Zum Hauptinhalt wechseln
Lenovo YOGA 730-15IKB Wireless Card Replacement
Was du brauchst
  1. Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 2, Bild 1 von 2 Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 2, Bild 2 von 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Wireless Card Replacement, Wireless Card: Schritt 4, Bild 1 von 1
    • Remove the sticky tape from the top edge of the wireless card.
  5. Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 5, Bild 1 von 3 Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 5, Bild 2 von 3 Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 5, Bild 3 von 3
    • Pull the black and white antenna wires off of the wireless card.
    • For reassembly, the white wire connects to the right terminal marked "1." The black wire connects to the left terminal marked "2."
  6. Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 6, Bild 1 von 2 Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 6, Bild 2 von 2
    • Remove one 2mm Phillips #1 screw.
  7. Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 7, Bild 1 von 2 Lenovo YOGA 730-15IKB Wireless Card Replacement: Schritt 7, Bild 2 von 2
    • Pull the wireless card out of the socket at its resting angle.
    • Do not pull straight upward. Pull towards the hinges at the back of the laptop.
Abschluss
Ellis Ruckman
2.509 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S1-G6, White Winter 2020 Mitglied von Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 59
Insgesamt: 2,959
