Einleitung
Follow this guide to replace the wireless card in your Lenovo YOGA 730-15IKB. The wireless card allows you to connect to Wi-Fi networks and access the internet. If your connection is slow or flaky, it might be worthwhile to upgrade your wireless card.
Also see the troubleshooting page to diagnose potential software issues related to Wi-Fi.
Was du brauchst
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Pry up the bottom cover with an opening tool.
Start at the front edge of the cover and make your way along the sides.
Pull the wireless card out of the socket at its resting angle.
Do not pull straight upward. Pull towards the hinges at the back of the laptop.
