Einleitung
This guide shows how to properly remove the back panel in order to replace the panel or access other parts of the computer for repair. This is removal is the way to gain access to the inner workings of the Lenovo Yoga 2 11” to test components or remove/replace components.
Was du brauchst
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Carefully remove the back panel by gently separating the panel from front to back.
