Zum Hauptinhalt wechseln
Lenovo Yoga 2 11" 20428 Battery Replacement
Was du brauchst
  1. Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: Schritt 1, Bild 2 von 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Battery Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Battery Replacement: Schritt 4, Bild 1 von 1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Battery Replacement: Schritt 5, Bild 1 von 2 Lenovo Yoga 2 11" 20428 Battery Replacement: Schritt 5, Bild 2 von 2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Battery Replacement: Schritt 6, Bild 1 von 2 Lenovo Yoga 2 11" 20428 Battery Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 23
Insgesamt: 701
