Zum Hauptinhalt wechseln
Lenovo Yoga 2 11" Battery Replacement
Was du brauchst
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: Schritt 2, Bild 1 von 1
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: Schritt 4, Bild 1 von 1
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: Schritt 5, Bild 1 von 2 Lenovo Yoga 2 11" Battery Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: Schritt 6, Bild 1 von 1
    • Once all of the wires are detached, carefully remove the battery and replace.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 4-3, Maness Fall 2015 Mitglied von Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Mitglieder
5 Anleitungen geschrieben
4 Kommentare
how do I remove unathorized battery error?
Manuel Durugas - Antwort
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - Antwort
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - Antwort
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 48
Insgesamt: 26,602
