Zum Hauptinhalt wechseln
Lenovo Yoga 2 13" Keyboard Keys Replacement
Was du brauchst
  1. Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: Schritt 1, Bild 1 von 2 Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: Schritt 1, Bild 2 von 2
    • Using a flat tool, carefully jimmy the selected key until it pops out.
  2. Lenovo Yoga 2 13" Keyboard Keys Replacement: Schritt 2, Bild 1 von 1
    • To insert a new key, simply place and apply pressure until it snaps into place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nichelle
1.550 Reputation
5 Anleitungen geschrieben
Marist, Team 1-2, Laflen Spring 2015 Mitglied von Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Mitglieder
7 Anleitungen geschrieben
4 Kommentare
this doesn't fix a non-working electric contact, does it?
Simon - Antwort
I came across this page since my Yoga 2 Pro had 2 keys that didn't press down very well. Instead of fully removing the keys, I used a flat tool to pry up the key a little bit, then used compressed air to clean out under the keys. I had to do this a few times from a few different angels, but it finally worked
and the keys feel like normal again.
a.adler55 - Antwort
Does this break the old keys so that you must replace them or is it possible to insert the same ones again?
Johannes Scheller - Antwort
For those who found this page in 2022, I’ll answer the old questions so you don’t have to look elsewhere.
This does not fix a non-working electrical contact, this is just for replacing the top.
Secondly no it does not break the old key if you do it carefully.
Kind Regards
Lost Yogi
Lost Yogi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 17,539
