Einleitung
This guide will explain how to safely remove the screen from your Lenovo Yoga 2 13" laptop. It will provide a list of the tools needed as well as the easiest way to remove the screen without damaging it.
Was du brauchst
Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
Locate the gold wire and follow it to two clips. Remove the clips and the clear tape securing the wire.
Gently unsnap the wire from the hooks along the perimeter, and remove any tape along the wire.
11 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
