Einleitung
Use this guide to replace the battery in your Lenovo Yoga 2 Pro.
Was du brauchst
Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
35 weitere Personen haben diese Anleitung absolviert.
14 Kommentare
The cover does not come off “gently”- there are snaps all the way around that must be popped.
where do I buy a quality replacement battery?
I checked ebay and amazon, and there are a bunch of them. But I don’t know which one I should buy.
Thanks in advance.
Did you find a suitable replacement? I’m curious too - looks like prices are $60 or twice that. Worth paying more than bargain basement prices?
drwelby -
You can get a Lenovo replacement battery from Amazon. About US 46. Did it, replaced, but now machine says no battery installed! Have searched far and wide on the web, but haven’t found an answer. Lots of complaints that Lenovo and new battery don’t mix well. Still searching. BTW I bought the replacement per my comments above. It’s an exact match and they put black tap over the Lenovo name.
