Zum Hauptinhalt wechseln
Lenovo Yoga 2 Pro SSD Replacement
Was du brauchst
    1. Lenovo Yoga 2 Pro SSD Replacement, SSD: Schritt 1, Bild 1 von 1
      • Please ensure that the laptop is turned off before beginning.
      • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
      Frag FixBot
      Kommentar hinzufügen
    2. Lenovo Yoga 2 Pro SSD Replacement: Schritt 2, Bild 1 von 1
      • Gently lift off the back cover.
      Frag FixBot
    3. Lenovo Yoga 2 Pro SSD Replacement: Schritt 3, Bild 1 von 1
      • Navigate to the top right corner of the laptop and locate the solid state drive next to the fan.
      • Using a Phillips #00 screwdriver, remove the one 3/16” screw from the top left corner of the solid state drive.
      • The solid state drive will lift up after you remove the screw.
      Frag FixBot
    4. Lenovo Yoga 2 Pro SSD Replacement: Schritt 4, Bild 1 von 2 Lenovo Yoga 2 Pro SSD Replacement: Schritt 4, Bild 2 von 2
      • To remove the solid state drive, gently slide it away from the battery and towards the hinges.
      Frag FixBot
Abschluss
24 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 12-14, Maness Fall 2015 Mitglied von Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Mitglieder
60 Anleitungen geschrieben
7 Kommentare zur Anleitung
Thanks for the clarity of the presentation. I am having difficulty with Lenovo identifying and purchasing a 256 GB replacement SSD for my yoga pro 2 laptop. Any suggestions about what the specs of that drive might be and where I can find one would be most appreciated.
Charles Wantman - Antwort Teilen
That looks like an M.2? I’m trying to figure that out myself, I’ll let you know if I find out.
Amethyst O'Connell - Antwort Teilen
Did you find it?  I would go to Amazon with part number mz-m5e250bw (it’s a Samsung card) … you don’t have to buy there.
I had to use a Torque #5 for the eleven screws on the back … the #00 Phillips was perfect for the SSD card itself.
jo diamond - Antwort Teilen
How do you put the new one in? By reversing the process?
Lauren Neal - Antwort Teilen
I am trying to find a reader for this old SSD. I purchased a M.2 NVME SATA SSD Enclosure Adapter, which I thought would work as a SATA PCIe M-Key(B+M Key) ssd reader but it doesn’t fit. Anyone point me towards a correct adapter?
YonA Dabs - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 91
Insgesamt: 36,246
