Zum Hauptinhalt wechseln
Lenovo Yoga 2 Pro Screen and Digitizer Replacement
Was du brauchst
    1. Lenovo Yoga 2 Pro Screen and Digitizer Replacement, Screen and Digitizer: Schritt 1, Bild 1 von 1
      • Open the laptop and remove the two screw covers on either side of the computer near the hinges using either the tip of a flathead screwdriver or a spudger.
      Frag FixBot
      Kommentar hinzufügen
    2. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 2, Bild 1 von 1
      • Remove the revealed two 3/16” screws using a Phillips #00 screwdriver.
      Frag FixBot
    3. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 3, Bild 1 von 1
      • Lift the two plastic bezel pieces off using a spudger.
      • Using a prying tool such as a spudger, gently lift the long plastic bezel piece away from the screen.
      • Be certain to only pry the plastic piece off, not anything under it. There are fragile components beneath it.
      Frag FixBot
    4. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 4, Bild 1 von 1
      • Remove the three 1/8” screws using a Phillips #00 screwdriver.
      Frag FixBot
    5. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 5, Bild 1 von 1
      • Gently remove the circuit board and set it aside.
      Frag FixBot
    6. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 6, Bild 1 von 1
      • Remove the last 1/8” screw near the middle of the screen using a Phillips #00 screwdriver.
      Frag FixBot
    7. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 7, Bild 1 von 1
      • Slide the screen up away from the hinges and lift from the backplate.
      Frag FixBot
    8. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 8, Bild 1 von 1
      • Fold the screen over and disconnect the LCD screen cable by lifting up the blue tab and pulling.
      Frag FixBot
    9. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 9, Bild 1 von 1
      • Remove the four 1/8” screws using a Phillips #00 screwdriver from the hinge on either side of the laptop.
      Frag FixBot
    10. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 10, Bild 1 von 1
      • Using a Torx T5 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
      Frag FixBot
    11. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 11, Bild 1 von 1
      • Gently lift off the back cover.
      Frag FixBot
    12. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 12, Bild 1 von 1
      • Remove the four 3/16” screws from the top of the laptop near the hinges using a Phillips #00 screwdriver.
      Frag FixBot
    13. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 13, Bild 1 von 1
      • Using a metal spudger, lift up the connector by the plastic near the top.
      • The connector lifts out of the computer, do not pull it to the sides.
      Frag FixBot
    14. Lenovo Yoga 2 Pro Screen and Digitizer Replacement: Schritt 14, Bild 1 von 1
      • Carefully remove the hinges and remove the screen.
      Frag FixBot
Abschluss
10 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 12-14, Maness Fall 2015 Mitglied von Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Mitglieder
60 Anleitungen geschrieben
6 Kommentare zur Anleitung
Thanks for the great tutorial! Any part number you can provide for this?
Dana Drummond - Antwort Teilen
I recently replaced my Lenovo Yoga 2 pro touch display, it was cracked and touch went crazy, the crack was from the side which made it usable by disabling the touch drivers. After a while i decided to replace the screen and get back the touch feature. but now i'm suffering that i cannot use it in tablet mode for the following reasons:
After screen replacement, when lid is closed it thinks that it is in tablet mode and screen stays on and doesn't go to sleep mode as it was before replacement, while if I put it in tablet position screen goes off and it goes to sleep mode thinking it is in closed lid position (i think). if i just  lift it up only 2 mm from tablet position it gets back on.
Please advise !!
Hussein Raouf - Antwort Teilen
I tried following these steps in reverse order, but I cant get step 7. I can get the glass placed correctly, but cant get it to slide back into place. Do you have any suggestions to get this step working?
Brittany Ann Kos - Antwort Teilen
My Y2P camera periodically disconnects when I move the screen at the hinges. Any idea if that cable is replaceable without replacing the screen?
Dylan Justice - Antwort Teilen
Can you advise on how to replace the leftmost LCD cable on Yoga 2 Pro with digitizer (touch) ?
Oyvind Overby - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 59
Insgesamt: 39,023
