Zum Hauptinhalt wechseln
Lenovo Yoga 3 11 Motherboard Replacement
Was du brauchst
    1. Lenovo Yoga 3 11 Motherboard Replacement, Lower Case: Schritt 1, Bild 1 von 1
      • Remove the eleven 6 mm T5 Torx screws securing the lower case.
      • Gently lift the lower case up and away from the device.
      Frag FixBot
      Kommentar hinzufügen
    1. Lenovo Yoga 3 11 Motherboard Replacement, Battery: Schritt 2, Bild 1 von 3 Lenovo Yoga 3 11 Motherboard Replacement, Battery: Schritt 2, Bild 2 von 3 Lenovo Yoga 3 11 Motherboard Replacement, Battery: Schritt 2, Bild 3 von 3
      • Remove the two 3 mm Phillips #00 screws securing the battery.
      • There are arrows on the battery indicating the location of the screws.
      Frag FixBot
    2. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 3, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • Use a pair of tweezers to gently disconnect the battery connector.
      Frag FixBot
    3. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 4, Bild 1 von 2 Lenovo Yoga 3 11 Motherboard Replacement: Schritt 4, Bild 2 von 2
      • Use a pair of tweezers to gently disconnect the speaker cable.
      • Remove the wires from underneath the battery tabs using the tweezers.
      Frag FixBot
    4. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 5, Bild 1 von 1
      • Carefully remove the battery from the device.
      Frag FixBot
    1. Lenovo Yoga 3 11 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
      • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
      Frag FixBot
    2. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 7, Bild 1 von 1
      • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
      Frag FixBot
    3. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 8, Bild 1 von 1
      • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
      Frag FixBot
    4. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 9, Bild 1 von 1
      • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
      Frag FixBot
    5. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 10, Bild 1 von 1
      • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
      Frag FixBot
    6. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 11, Bild 1 von 3 Lenovo Yoga 3 11 Motherboard Replacement: Schritt 11, Bild 2 von 3 Lenovo Yoga 3 11 Motherboard Replacement: Schritt 11, Bild 3 von 3
      • Use a pair of tweezers to disconnect the "I/O Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
      • Use a pair of tweezers to disconnect the "MB Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
      • Remove the ribbon cable from the device.
      Frag FixBot
    7. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 12, Bild 1 von 3 Lenovo Yoga 3 11 Motherboard Replacement: Schritt 12, Bild 2 von 3 Lenovo Yoga 3 11 Motherboard Replacement: Schritt 12, Bild 3 von 3
      • Remove the two 2 mm Phillips #00 screws securing the wireless card (top) and the SSD (bottom).
      • Use a pair of tweezers to disconnect the black and white antenna cables that are connected to the wireless card.
      • Gently lift the wireless card and SSD up and out of the device.
      Frag FixBot
    8. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 13, Bild 1 von 1
      • Remove the three black 2 mm Phillips #00 screws.
      • Remove the single silver 4 mm Phillips #00 screw.
      Frag FixBot
    9. Lenovo Yoga 3 11 Motherboard Replacement: Schritt 14, Bild 1 von 1
      • Gently lift the motherboard up and out of the device.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 2-3, Blackwell Fall 2015 Mitglied von USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Mitglieder
71 Anleitungen geschrieben
1 Kommentar zur Anleitung
Not as difficult as I thought. I was surprised that there were no empty RAM locations. Usually on a Notebookk lliek this, there is one RAM location soldered to MB, and one empty slot for upgrade. I worked on an identical Yoga 3 pro that ran 16GB. But aht meant it was soldered at factory to one 16GB RAM setup.
Mick Thielen - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 39
Insgesamt: 8,081
