Zum Hauptinhalt wechseln
Lenovo Yoga 3 14 Speaker Replacement
Was du brauchst
  1. Lenovo Yoga 3 14 Speaker Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 Speaker Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga 3 14 Speaker Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga 3 14 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 Speaker Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 Speaker Replacement: Schritt 4, Bild 1 von 3 Lenovo Yoga 3 14 Speaker Replacement: Schritt 4, Bild 2 von 3 Lenovo Yoga 3 14 Speaker Replacement: Schritt 4, Bild 3 von 3
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 1
    • Using a pair of tweezers, dissconnect the speakers on the left side of the laptop.
  6. Lenovo Yoga 3 14 Speaker Replacement: Schritt 6, Bild 1 von 2 Lenovo Yoga 3 14 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Flip up the black retaining flap on the ZIF connector.
    • Using tweezers, gently disconnect the blue strip that connects the touch pad to the motherboard.
  7. Lenovo Yoga 3 14 Speaker Replacement: Schritt 7, Bild 1 von 2 Lenovo Yoga 3 14 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Use tweezers to gently pull off tape that is holding down wires that are connecting the two speakers together.
  8. Lenovo Yoga 3 14 Speaker Replacement: Schritt 8, Bild 1 von 2 Lenovo Yoga 3 14 Speaker Replacement: Schritt 8, Bild 2 von 2
    • Both speakers are held in place by plastic pegs. Gently lift the speakers off the casing to remove them.
  9. Lenovo Yoga 3 14 Speaker Replacement: Schritt 9, Bild 1 von 2 Lenovo Yoga 3 14 Speaker Replacement: Schritt 9, Bild 2 von 2
    • Simply grip the speaker wires and lift away from laptop to remove.
Abschluss
USF Tampa, Team 3-2, Passmore Fall 2016 Mitglied von USF Tampa, Team 3-2, Passmore Fall 2016
USFT-PASSMORE-F16S3G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 1,247
