Zum Hauptinhalt wechseln
Lenovo Yoga 3 14 USB Port Replacement
Was du brauchst
  1. Lenovo Yoga 3 14 USB Port Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 USB Port Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga 3 14 USB Port Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga 3 14 USB Port Replacement: Schritt 2, Bild 3 von 3
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 USB Port Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 USB Port Replacement: Schritt 4, Bild 1 von 3 Lenovo Yoga 3 14 USB Port Replacement: Schritt 4, Bild 2 von 3 Lenovo Yoga 3 14 USB Port Replacement: Schritt 4, Bild 3 von 3
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 USB Port Replacement, USB Port: Schritt 5, Bild 1 von 2 Lenovo Yoga 3 14 USB Port Replacement, USB Port: Schritt 5, Bild 2 von 2
    • Take out the 3, 3mm screws from the left hinge using the PH0 head.
    • Remove the 1, 4mm screw that connects the hinge to the USB port.
    • Carefully lift the hinge enough to separate it from the USB port.
  6. Lenovo Yoga 3 14 USB Port Replacement: Schritt 6, Bild 1 von 2 Lenovo Yoga 3 14 USB Port Replacement: Schritt 6, Bild 2 von 2
    • Using the tweezers, carefully lift the black clip and remove the electrical ribbon.
  7. Lenovo Yoga 3 14 USB Port Replacement: Schritt 7, Bild 1 von 1
    • The USB port is held in place by plastic pegs. Gently lift up to remove the USB port from the laptop.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 3-2, Passmore Fall 2016 Mitglied von USF Tampa, Team 3-2, Passmore Fall 2016
USFT-PASSMORE-F16S3G2
4 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
Anyone know where I can buy this part? Cannot find it anywhere…
Nicolas Petersen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 2,100
