Zum Hauptinhalt wechseln
Lenovo Yoga 3 Pro Speakers Replacement
Was du brauchst
  1. Lenovo Yoga 3 Pro Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Speakers Replacement: Schritt 2, Bild 1 von 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Speakers Replacement: Schritt 4, Bild 1 von 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Speakers Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Speakers Replacement: Schritt 6, Bild 1 von 1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro Speakers Replacement, Speakers: Schritt 7, Bild 1 von 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro Speakers Replacement: Schritt 8, Bild 1 von 2 Lenovo Yoga 3 Pro Speakers Replacement: Schritt 8, Bild 2 von 2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro Speakers Replacement: Schritt 9, Bild 1 von 3 Lenovo Yoga 3 Pro Speakers Replacement: Schritt 9, Bild 2 von 3 Lenovo Yoga 3 Pro Speakers Replacement: Schritt 9, Bild 3 von 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro Speakers Replacement: Schritt 10, Bild 1 von 2 Lenovo Yoga 3 Pro Speakers Replacement: Schritt 10, Bild 2 von 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro Speakers Replacement: Schritt 11, Bild 1 von 2 Lenovo Yoga 3 Pro Speakers Replacement: Schritt 11, Bild 2 von 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 12-17, Maness Fall 2015 Mitglied von Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 21
Insgesamt: 2,852
