Einleitung
Over time, the USB ports collect dust, dirt, and can become damaged for a multitude of reasons all of which ultimately lead to connectivity issues. This guide will help you remove the USB ports in order to clean or replace them.
Was du brauchst
Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
Slide the plastic opening tool between the base cover and the frame to pry open the computer.
Slowly go around the entire perimeter of the computer until all edges are loose.
Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
Remove the speaker and set it on the side.
Use the plastic opening tool to remove the cables.
Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
10 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
This guide helped me quite a bit today. I really appreciate you providing it.
None of the 3 USB ports were powering on.
Windows seemed happy and no drivers and bios update helped …
I took apart following this guide, cleaned all ports and PCBs with IPA and a toothbrush and now it’s all working again!
Thank you
