Einleitung
The back panel covers and protects all the internal components of the laptop. Only remove this cover if you need to service or replace major internal components inside of the laptop. If your back panel is damaged or broken, use this guide to remove and replace it.
Was du brauchst
Flip your device so that the bottom panel is facing up.
Remove the eleven 5mm Torx T5 screws from the back panel.
Use a spudger to unclip clips on the front and near the USB ports on each side
Lift the back panel off
2 weitere Personen haben diese Anleitung absolviert.
