Einleitung
Guide to removing the back cover of your Lenovo laptop. Prerequisite to all other replacement guides.
Was du brauchst
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
