Einleitung
This guide will teach you how to remove and replace the cooling fan on your Lenovo Yoga laptop.
Was du brauchst
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
Use your fingernail or a plastic tool to disconnect the fan power cable from the circuit board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Thanks for a great guide! This is a great laptop with a really noisy cheep fan... It makes a high pitch sound even under the low load. Is it possible to make it run any better??
I have searched online for a replacement fan for the Yoga 710-14ikb but havent found any. Is it possible to use a fan for another model, perhaps the 14isk or 15ikb?
I did find this but dont want to wait that long. https://www.aliexpress.com/item/New-lapt...
does anyone know the best place to buy a new one of these fans?
