Was du brauchst
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
