Zum Hauptinhalt wechseln
Lenovo Yoga 710-14IKB SSD Replacement
Was du brauchst
  1. Lenovo Yoga 710-14IKB SSD Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB SSD Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga 710-14IKB SSD Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga 710-14IKB SSD Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB SSD Replacement, SSD: Schritt 3, Bild 1 von 2 Lenovo Yoga 710-14IKB SSD Replacement, SSD: Schritt 3, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the 3mm screw on the SSD.
  4. Lenovo Yoga 710-14IKB SSD Replacement: Schritt 4, Bild 1 von 2 Lenovo Yoga 710-14IKB SSD Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Grant Doerksen
1.005 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S14-G5, Banghart Spring 2017 Mitglied von Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
4 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 61
Insgesamt: 11,196
