Einleitung
This simple guide will show you how to remove the two speakers from a Lenovo Yoga 710-14KB.
Was du brauchst
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
Locate the speaker's plug and disconnect it.
Follow the wires connected to the plug to locate the speakers. The left speaker will have red wires, and the right speaker will have blue wires.
Untangle the wires from the plastic hinges of the case to properly lift the speakers out.
