Zum Hauptinhalt wechseln
Lenovo Yoga 710-14IKB Trackpad Replacement
Was du brauchst
  1. Lenovo Yoga 710-14IKB Trackpad Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Trackpad Replacement, Battery: Schritt 3, Bild 1 von 2 Lenovo Yoga 710-14IKB Trackpad Replacement, Battery: Schritt 3, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 4, Bild 1 von 2 Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Trackpad Replacement, Trackpad: Schritt 6, Bild 1 von 1
    • Use the Phillips #1 screwdriver to take off the three 3mm screws.
  7. Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 7, Bild 1 von 2 Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 7, Bild 2 von 2
    • Grip the blue tab and pull out.
    • Careful to not pull too hard, there is a chance of damaging the tab.
  8. Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 8, Bild 1 von 2 Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 8, Bild 2 von 2
    • Lift off the layer of tape from the trackpad.
  9. Lenovo Yoga 710-14IKB Trackpad Replacement: Schritt 9, Bild 1 von 1
    • Push out the trackpad.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Chuefeng Vang
136 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 Mitglied von UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G8
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 33
Insgesamt: 1,676
