Zum Hauptinhalt wechseln
Lenovo Yoga 710-15IKB Back Cover Replacement
Was du brauchst
  1. Lenovo Yoga 710-15IKB Back Cover Replacement, Lenovo Yoga 710-15IKB Back Cover Replacement: Schritt 1, Bild 1 von 1
    • Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
  2. Lenovo Yoga 710-15IKB Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Slide opening tool between the base and back cover.
  3. Lenovo Yoga 710-15IKB Back Cover Replacement: Schritt 3, Bild 1 von 1
    • Lift the back cover.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
University of Maine, Team S1-G5, Diaz Fall 2017 Mitglied von University of Maine, Team S1-G5, Diaz Fall 2017
UMAINE-DIAZ-F17S1G5
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare zur Anleitung
Hello,
i am looking for lenovo yoga 710 15” laptop lcd and top body part, where lcd fixed. please suggest.
Thanks & Regards,
Vilas
salvivilas@gmail.com
sunilkedar - Antwort Teilen
You can get the screens for these fairly easily online, the only problem is the special command adhesive that goes with it doesn’t exist. I have been struggling to get this screen to stick using the recommended 3m adhesive alternative. The screen just wont stick! It appears to stick for weeks without issue but eventually this fails.
service - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 35
Insgesamt: 3,502
