Einleitung
This guide is useful for broken, inefficient, or defective fans within a Lenovo Yoga 710-15IKB. For loud or overheating fans, use this guide after confirming that dust is not the cause for fan issues.
Was du brauchst
Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
Use tweezers to grab the fan harness.
Gently pull the harness to disconnect from motherboard.
Eine weitere Person hat diese Anleitung absolviert.
