Einleitung
Solid state drives are known to fail occasionally, but this doesn't mean you have to do away with your laptop entirely. Replacing a bad drive is as simple as removing the battery and a single screw. Failure can be caused by heat, voltage fluctuation, and age.
Was du brauchst
Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
Remove the one JIS 1 screw holding the solid state drive in place.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
