Zum Hauptinhalt wechseln
Lenovo Yoga 710-15ISK Battery Replacement
Was du brauchst
  1. Lenovo Yoga 710-15ISK Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Lenovo Yoga 710-15ISK Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver. The location of the screws is encircled in the photo.
  2. Lenovo Yoga 710-15ISK Battery Replacement: Schritt 2, Bild 1 von 1
    • Gently remove the back cover of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Lenovo Yoga 710-15ISK Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the laptop.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Elisa Normand
423 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 3-5, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-5, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G5
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 688
