Zum Hauptinhalt wechseln
Lenovo Yoga 710-15ISK Motherboard Replacement
Was du brauchst
  1. Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver. The location of the screws is encircled in the photo.
  2. Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Gently remove the back cover of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: Schritt 3, Bild 1 von 2 Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the laptop.
  6. Lenovo Yoga 710-15ISK Motherboard Replacement, Fans: Schritt 6, Bild 1 von 1
    • Remove the four 1.5 mm screws from the fans with a Phillips #00 screwdriver.
  7. Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Unplug the wire connecting the fan to the motherboard by gently pulling the white head from the port.
  8. Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 8, Bild 1 von 2 Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Lift both fans to remove them from the laptop.
  9. Lenovo Yoga 710-15ISK Motherboard Replacement, SSD: Schritt 9, Bild 1 von 1
    • Remove the sticker from the SSD to gain access to the screw underneath.
  10. Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 10, Bild 1 von 2 Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the screw holding the SSD in place using a Phillips #0 screwdriver.
    • Gently pull on the plastic clip next to the screw until the stick is freed and bounces up.
  11. Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Slide the SSD out of the laptop.
  12. Lenovo Yoga 710-15ISK Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Remove seven 2 mm screws from the motherboard using a Phillips #0 screwdriver.
  13. Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 13, Bild 1 von 3 Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 13, Bild 2 von 3 Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Unplug four cables attached to the motherboard.
    • For the flat ribbon wires, lift the black tabs holding them in place before removing them.
  14. Lenovo Yoga 710-15ISK Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Carefully lift out the motherboard to remove it from the laptop.
Abschluss
Annette Limoges
181 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 368
