Einleitung
This guide will show you how to replace the RAM in your Lenovo Yoga 710-15ISK laptop. The memory of your laptop is an essential component that determines how many programs can be running at once. If you find your laptop is running slowly, you may want to upgrade or replace your memory.
Important: Ensure you purchase a RAM stick compatible with your laptop's specifications. Verify the correct type, speed, and capacity, as using incompatible RAM can cause performance issues or damage your device.
Before you begin the repair, make sure that your laptop is powered off and unplugged from the charger.
Was du brauchst
Flip your laptop over so the bottom is facing upwards.
Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver. The location of the screws is encircled in the photo.
Use the spudger to detach the clips holding the RAM cover.
Gently pry the RAM cover up off of the motherboard using the spudger.
Use your fingers to take apart the clips holding the RAM in place.
Carefully slide the RAM out of its slot.
Congratulations! You’ve successfully replaced the RAM in your Lenovo Yoga 710-15ISK. Enjoy the enhanced performance, whether for multitasking or demanding applications. If you encounter issues, refer to your laptop’s manual or seek professional assistance.
