Zum Hauptinhalt wechseln
Lenovo Yoga 720-12IKB Headphone Jack Replacement
Was du brauchst
  1. Lenovo Yoga 720-12IKB Headphone Jack Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Headphone Jack Replacement: Schritt 3, Bild 1 von 2 Lenovo Yoga 720-12IKB Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Headphone Jack Replacement: Schritt 4, Bild 1 von 2 Lenovo Yoga 720-12IKB Headphone Jack Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Finally remove the battery from the case.
  6. Lenovo Yoga 720-12IKB Headphone Jack Replacement, Headphone Jack: Schritt 6, Bild 1 von 1
    • The headphone jack can be found on the top right of the chassis.
    • Start by removing the 2.0 mm Phillips #00 screw.
  7. Lenovo Yoga 720-12IKB Headphone Jack Replacement: Schritt 7, Bild 1 von 1
    • Undo the clip and remove the connector.
  8. Lenovo Yoga 720-12IKB Headphone Jack Replacement: Schritt 8, Bild 1 von 1
    • Pull the connector to the right to remove it from the clip.
  9. Lenovo Yoga 720-12IKB Headphone Jack Replacement: Schritt 9, Bild 1 von 1
    • Remove the headphone jack from the chassis.
Abschluss
Alex Escobar
778 Reputation
6 Anleitungen geschrieben
Gateway, Team 1-4, Pee Spring 2022 Mitglied von Gateway, Team 1-4, Pee Spring 2022
GCC-PEE-S22S1G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 208
