Einleitung
If you are experiencing a loose or dirty headphone jack on your laptop then you will have to replace the headphone jack on the Lenovo 720-12IKB
The headphone jack on the Lenovo 720-12IKB is necessary to listen to the audio through a headset.
Use caution when replacing components in your Laptop as you could damage other components.
Was du brauchst
Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
Pull down on the cover to remove it and you will see the battery after removing the cover.
Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
The headphone jack can be found on the top right of the chassis.
Start by removing the 2.0 mm Phillips #00 screw.
