Zum Hauptinhalt wechseln
Lenovo Yoga 720-12IKB Motherboard Replacement
Was du brauchst
  1. Lenovo Yoga 720-12IKB Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 3, Bild 1 von 2 Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 4, Bild 1 von 2 Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Finally remove the battery from the case.
  6. Lenovo Yoga 720-12IKB Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • The motherboard is located above the battery.
  7. Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Unscrew and remove the 2.0 mm Phillips #00 screws.
  8. Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 8, Bild 1 von 2 Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the connectors by lifting up the clip and pulling them out.
  9. Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the 4.0 mm Phillips #00 screws from the fan.
    • Remove the 4.0 mm Phillips #00 screws from the heatsink.
  10. Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 10, Bild 1 von 2 Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the 5.5 mm Phillips #00 screws from the hinge.
    • Remove the 4.0 mm Phillips #00 screws froom the hinge.
    • Open the laptop a little to lift the hinge.
  11. Lenovo Yoga 720-12IKB Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the motherboard after all screws are out and connectors are disconnected.
Abschluss
Alex Escobar
778 Reputation
6 Anleitungen geschrieben
Gateway, Team 1-4, Pee Spring 2022 Mitglied von Gateway, Team 1-4, Pee Spring 2022
GCC-PEE-S22S1G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 365
