Was du brauchst
Remove seven Torx T5 short screws.
Remove three Torx T5 long screws.
In diesem Schritt verwendetes Werkzeug:iFixit Opening Tool$1.99
Starting from the USB port, use your opening tool to gently pry up the case.
Pry along the laptop in the order shown by the arrows.
Lift the case from the bottom side. NOT the side with the hinges.
Once you feel resistance, gently pull the case towards you. (away from the hinges.)
Remove the case.
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
Pull the battery towards you until the wire is accessible.
gently tug and wiggle on the wire until it pops out.
Remove the battery.
Use a Torx T5 screwdriver to remove the eight 8mm screws holding the touchpad in place.
Lift the small black tab on the single ZIF connector in the center of the touchpad, and gently pull the white ribbon cable free.
Gently peel the silver conductive tape away from the touchpad shielding.
Remove the touchpad.
Eine weitere Person hat diese Anleitung absolviert.
