Einleitung
This guide shows you how to replace the Lenovo Yoga 720 15-IKB (88YG7000828) battery. Batteries tend to wear out over time, so if your battery isn’t holding a charge as long as it should, you might need to replace it. Refer to the troubleshooting page for more information about symptoms.
Werkzeuge
Ersatzteile
Power off the device before starting.
Flip the device over with the hinges facing away from you.
Remove seven 5.0 mm Torx T5 screws.
Remove three 9.5 mm Torx T5 screws.
Pry around the edges from one side to another with a plastic opening tool.
Lift the case from the front until you feel resistance.
Pull the cover towards you, away from the hinges.
Completely lift off the cover.
Remove the four 4mm screws surrounding the battery with a Phillips #0 screwdriver.
3 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
Excellent guide. Made the job a snap. Especially identifying the screwdriver bit requird.
