Was du brauchst
Starting at the left USB port use you opening tool to gently pry up the bottom case.
Pry along the laptop's edge as shown by the arrows.
Lift the case from the bottom side. NOT the side with the hinges.
Once you feel resistance, gently pull the case towards you. (away from the hinges.)
Remove the bottom case.
Fast fertig!
Abschluss
