Einleitung
If the screen in the Lenovo Yoga 720-15IKB is not properly displaying images or is cracked, it may be time to replace it. Follow these instructions to replace the display in your laptop.
Was du brauchst
Power off the device before starting.
Flip the device over with the hinges facing away from you.
Remove seven 5.0 mm Torx T5 screws.
Remove three 9.5 mm Torx T5 screws.
Pry around the edges from one side to another with a plastic opening tool.
Lift the case from the front until you feel resistance.
Pull the cover towards you, away from the hinges.
Completely lift off the cover.
Remove the 6, 2.5x5 screws, located on the hinges of the underside of the device.
Separate the display from the back panel. The display should be away from the actual computer itself.
Use the opening picks and opening tool to pry off each side without cracking the display.
Once that is finished, carefully lift it up and place it on a safe surface.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
This method didn't work for me. The screen is stuck to the lid with tape that has to be pulled from the bottom in order to release the screen without breaking it. I had to buy a new screen with tape.
