Einleitung
If your computer is showing the blue screen of death (BSoD) or is not functioning properly, it may be time to replace the motherboard. Follow these instructions to replace the motherboard in the Lenovo Yoga 720-15IKB.
Was du brauchst
Power off the device before starting.
Flip the device over with the hinges facing away from you.
Remove seven 5.0 mm Torx T5 screws.
Remove three 9.5 mm Torx T5 screws.
Pry around the edges from one side to another with a plastic opening tool.
Lift the case from the front until you feel resistance.
Pull the cover towards you, away from the hinges.
Completely lift off the cover.
Remove the six 5.2mm Torx T5 screws holding the fan in place.
Remove the five 5.0mm Torx T5 screws holding the fan in place.
Remove the four 4mm screws surrounding the battery with a Phillips #0 screwdriver.
Disconnect the power outlet connector.
Disconnect the speaker wire connector.
Carefully lift the motherboard up and out of the device.
