Zum Hauptinhalt wechseln
Lenovo Yoga 720-15IKB Speakers Replacement
Was du brauchst
  1. Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: Schritt 1, Bild 1 von 3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: Schritt 1, Bild 2 von 3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: Schritt 1, Bild 3 von 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Speakers Replacement: Schritt 2, Bild 1 von 2 Lenovo Yoga 720-15IKB Speakers Replacement: Schritt 2, Bild 2 von 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: Schritt 3, Bild 1 von 3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: Schritt 3, Bild 2 von 3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: Schritt 3, Bild 3 von 3
    • Here are the speakers for this device.
    • Pull the right speaker straight up and remove it from the computer.
    • As you remove the speaker, make sure to also carefully pull the wire connected to the speaker out along with the speaker.
  4. Lenovo Yoga 720-15IKB Speakers Replacement: Schritt 4, Bild 1 von 1
    • Remove the left speaker similarly to how the right speaker was removed.
  5. Lenovo Yoga 720-15IKB Speakers Replacement: Schritt 5, Bild 1 von 1
    • Unplug the speaker by firmly pulling the wire out of the socket.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jeremy Kostel
249 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S19-G3, White Winter 2020 Mitglied von Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Mitglieder
25 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 375
