Zum Hauptinhalt wechseln
Lenovo Yoga 730-13IKB Heat Sink Replacement
Was du brauchst
  1. Lenovo Yoga 730-13IKB Heat Sink Replacement, Back Case: Schritt 1, Bild 1 von 3 Lenovo Yoga 730-13IKB Heat Sink Replacement, Back Case: Schritt 1, Bild 2 von 3 Lenovo Yoga 730-13IKB Heat Sink Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Heat Sink Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga 730-13IKB Heat Sink Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga 730-13IKB Heat Sink Replacement: Schritt 2, Bild 3 von 3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Heat Sink Replacement: Schritt 3, Bild 1 von 1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Heat Sink Replacement, Heat Sink: Schritt 4, Bild 1 von 2 Lenovo Yoga 730-13IKB Heat Sink Replacement, Heat Sink: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the eight 2.5mm screws securing the heat sink assembly.
  5. Lenovo Yoga 730-13IKB Heat Sink Replacement: Schritt 5, Bild 1 von 2 Lenovo Yoga 730-13IKB Heat Sink Replacement: Schritt 5, Bild 2 von 2
    • Release the fan connector by gently pushing the gray locking tab up using a plastic spudger. Do this for both of the fans.
    • Pull each fan cable straight out of the connector.
  6. Lenovo Yoga 730-13IKB Heat Sink Replacement: Schritt 6, Bild 1 von 1
    • Remove the heat sink assembly by holding the middle plate and rotating the assembly down towards the back of the motherboard.
    • Pull the heat sink diagonally away from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Colin Reay
848 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G1, White Winter 2020 Mitglied von Cal Poly, Team S1-G1, White Winter 2020
CPSU-WHITE-W20S1G1
3 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
gdje i kako kupiti hladnjak za lenovo yoga 730-13 sa zamjenu
Smajo Avdic - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 19
Letzte 30 Tage: 24
Insgesamt: 956
