Zum Hauptinhalt wechseln
Lenovo Yoga 910-13IKB Fan Replacement
Was du brauchst
  1. Lenovo Yoga 910-13IKB Fan Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo Yoga 910-13IKB Fan Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Fan Replacement, Battery: Schritt 2, Bild 1 von 1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 3, Bild 1 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 3, Bild 2 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Fan Replacement, Fan: Schritt 4, Bild 1 von 2 Lenovo Yoga 910-13IKB Fan Replacement, Fan: Schritt 4, Bild 2 von 2
    • Remove the screws attached to the SSD stick by using a Phillips #0 screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
  5. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 5, Bild 1 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 5, Bild 2 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 5, Bild 3 von 3
    • Lift the labeled flap seal and remove the ribbon cable that connects the USB ports to the motherboard and gently pull away.
    • Be gentle when detaching the cables, the attachment port is easy to damage.
  6. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 6, Bild 1 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 6, Bild 2 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the single 1 mm screw at the left of Wi-Fi card with a Phillips #0 screwdriver.
    • Remove the Wi-Fi card by gently pulling the card to the left.
  7. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 7, Bild 1 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 7, Bild 2 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 7, Bild 3 von 3
    • Unscrew three 1 mm screws on the rightmost USB port board using a Phillips #0 screwdriver.
    • Remove the rightmost USB port board by pulling it up and out.
  8. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 8, Bild 1 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 8, Bild 2 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 8, Bild 3 von 3
    • Unscrew the four 1 mm screws on the leftmost USB port using a Phillips #0 screwdriver.
    • Remove the leftmost USB port board by pulling it up and out.
  9. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 9, Bild 1 von 2 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 9, Bild 2 von 2
    • Remove seven 1 mm screws from the motherboard using a Phillips #0 screwdriver.
  10. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 10, Bild 1 von 2 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 10, Bild 2 von 2
    • Gently pull the Back Connector strip towards you, this will safely disconnect it.
    • Disconnect the two Upper Connector Strips by using Tweezers and unclipping the upper tab.
    • Be cautious not to rip the strips or parts.
  11. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 11, Bild 1 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 11, Bild 2 von 3 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 11, Bild 3 von 3
    • Gently peel up the sticky adhesive attaching the fan to the hinge.
    • Be very careful with the ports when removing to not damage anything else.
  12. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 12, Bild 1 von 2 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 12, Bild 2 von 2
    • Remove the motherboard and fan by pulling away and up from the hinge.
  13. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 13, Bild 1 von 2 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 13, Bild 2 von 2
    • Flip the component to the opposite side.
  14. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 14, Bild 1 von 2 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 14, Bild 2 von 2
    • Remove three 1 mm screws using a Phillips #0 screwdriver.
  15. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 15, Bild 1 von 2 Lenovo Yoga 910-13IKB Fan Replacement: Schritt 15, Bild 2 von 2
    • Lift the leftmost flap seal up and remove the connector strip.
    • Lift the two right flap seals up and remove the connector strip.
    • Using tweezers or a spudger may be helpful.
  16. Lenovo Yoga 910-13IKB Fan Replacement: Schritt 16, Bild 1 von 1
    • Lift the fan component upward and away from the motherboard.
Abschluss
To reassemble your device, follow steps 1-8 in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
This laptop throttles like crazy with heavy load even if both fans are working perfectly!
danwat1234 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 34
Insgesamt: 1,258
