Zum Hauptinhalt wechseln
Lenovo Yoga 920-13IKB Audio Jack Replacement
Was du brauchst
  1. Lenovo Yoga 920-13IKB Audio Jack Replacement, Back Cover: Schritt 1, Bild 1 von 2 Lenovo Yoga 920-13IKB Audio Jack Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 2, Bild 3 von 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Audio Jack Replacement, Motherboard: Schritt 3, Bild 1 von 2 Lenovo Yoga 920-13IKB Audio Jack Replacement, Motherboard: Schritt 3, Bild 2 von 2
    • Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
  4. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 4, Bild 1 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 4, Bild 2 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 4, Bild 3 von 3
    • Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
  5. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 5, Bild 1 von 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 5, Bild 2 von 2
    • Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
  6. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 6, Bild 1 von 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
  7. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 7, Bild 1 von 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
  8. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 8, Bild 1 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 8, Bild 2 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 8, Bild 3 von 3
    • Lift the motherboard up parallel to the hinge of the device.
    • Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
    • Avoid pulling the motherboard all the way out until the green AC card is disconnected.
  9. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 9, Bild 1 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 9, Bild 2 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 9, Bild 3 von 3
    • Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
  10. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 10, Bild 1 von 1
    • Flip the motherboard over to access the back side.
  11. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 11, Bild 1 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 11, Bild 2 von 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 11, Bild 3 von 3
    • Remove four 3mm JIS #00 screws with the screwdriver.
    • Remove one 3mm Phillips #00 screw with the screwdriver.
    • The screws stay attached to the speaker when removed from the motherboard.
  12. Lenovo Yoga 920-13IKB Audio Jack Replacement: Schritt 12, Bild 1 von 1
    • Separate the fans from the motherboard to isolate it for replacement.
  13. Lenovo Yoga 920-13IKB Audio Jack Replacement, Audio Jack: Schritt 13, Bild 1 von 1
    • Replace the motherboard to replace the audio jack.
Abschluss
Cal Poly, Team S2-G3, White Winter 2019 Mitglied von Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Mitglieder
29 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 805
