Einleitung
This guide shows how to replace the fingerprint sensor on the Lenovo Yoga 920-13IKB.
Was du brauchst
Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
Slide the iFixit Opening Tool under the back cover to lift it up.
Pull up on the cover with your hand to release the tab holding the center of the cover in place.
Remove the four 5mm Phillips #00 screws that hold the battery in place.
Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
Lift up the cover on the fingerprint sensor using the iFixit Opening Tool and remove the cover from the sensor.
Flip up the cable connector tab using the iFixit Opening Tool to release the ribbon wire.
Lift the fingerprint sensor with the iFixit Opening Tool and remove it from the device.
