Zum Hauptinhalt wechseln
Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement
Was du brauchst
  1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: Schritt 1, Bild 1 von 2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 2, Bild 3 von 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: Schritt 3, Bild 1 von 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: Schritt 3, Bild 2 von 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: Schritt 3, Bild 3 von 3
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 4, Bild 1 von 2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 4, Bild 2 von 2
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 5, Bild 1 von 1
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery.
  7. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Fingerprint Sensor: Schritt 7, Bild 1 von 1
    • Remove the 3mm Phillips #00 Screw to loosen the sensor.
  8. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 8, Bild 1 von 1
    • Lift up the cover on the fingerprint sensor using the iFixit Opening Tool and remove the cover from the sensor.
  9. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 9, Bild 1 von 1
    • Flip up the cable connector tab using the iFixit Opening Tool to release the ribbon wire.
  10. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 10, Bild 1 von 1
    • Unplug the ribbon wire from the sensor to completely free the sensor.
  11. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: Schritt 11, Bild 1 von 1
    • Lift the fingerprint sensor with the iFixit Opening Tool and remove it from the device.
Abschluss
Cal Poly, Team S2-G3, White Winter 2019 Mitglied von Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Mitglieder
29 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 40
Insgesamt: 851
