Einleitung
This guide will show you how to replace the USB-C Ports on the Lenovo Yoga 920-12IKB.
Was du brauchst
Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
Slide the iFixit Opening Tool under the back cover to lift it up.
Pull up on the cover with your hand to release the tab holding the center of the cover in place.
Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
Lift the motherboard up parallel to the hinge of the device.
Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
Remove four 3mm JIS #00 screws with the screwdriver.
Remove one 3mm Phillips #00 screw with the screwdriver.
3 weitere Personen haben diese Anleitung absolviert.
